I know there was a post about this a little while back. I am sort of rehashing the subject. I have been scanning now for a few months analog (BC355N). I am currently utilizing an old homemade J Pole mounted on the my rooftop with a 40 ft.run of old 75ohm coax straight to the receiver. I receive my local Fire, Police, Sherriff stations all really clear in the 151-159 MHZ range. I even get the county to my south in terms of the Sherriff's office, also in the 151-159 MHZ range very clear. My Air band frequencies 119 to 135 MHZ are what I would call adequate, at least for all towers within 250 miles. I notice I am very weak in the UHF frequencies 420 and higher. Also, I plan on upgrading to a Digital Scanner some time in 2016. I am located well above 750 ft. sea level on a hill so I have relative good antenna location as a whole.
Therefore my Question: I am seriously considering buying the Diamond D130N with a 75 ft. run of LMR400 50ohm cable in order to replace my J Pole set up as my primary Scanning Antenna. The new Diamond D130N would be mounted above my existing UHF/VHF TV Antenna, which is on the other side of my roof, about 5 feet higher than my j pole location (the reason for 75 ft of cable vs. existing 45 ft. to the J Pole. Given the fact that I am desiring improvement in the UHF band and higher and that I desire to have an improved signal reception when I buy my new digital scanner, in everyone's opinion, is this a good buy? Or, should I save my money for something else and just keep using the J Pole. Bottom line, I don't want to buy this Diamond and end up getting the same results as my J Pole that I spent maybe 25.00 making and is working okay for right now.
