Yes, I know...beat to death...search...all that. I did, and I'm likely just not searching with the correct terms.
Also, I'm NOT ARGUING the point, just trying to get a better understanding
From the "out of band" sticky -
I 100%, completely, understand the technical aspect of spurious emissions and the like when going outside of the band the radio was designed for. I 100% understand the Part X acceptances, and why the non ham radios need to have Part X acceptance for use on their intended bands. I understand that ham radios aren't Part X accepted, and that we can home brew equipment. Or...maybe I don't understand them at all, and that's my problem
I believe I understand that if I take, say, a random Yaesu 2 meter radio and modify it for use on the public service band around 150Mhz, it may cause undesired interference on that band, potentially the 2 meter band, and even bands that aren't even close to those frequencies, and that's why I can't modify ham radios to work on non ham bands. Makes perfect sense.
Where I believe my failure to understand is that isn't that the same deal if I home brew a 2 meter radio, and use it on 2 meters? After all, we are "amateurs" here, not necessarily professionals. If I don't fully understand what I'm doing when designing/building/tuning a radio I built from scratch, aren't I still potentially going to cause that same undesired interference on 150 or 138 or whatever, despite being "legal" in what I'm doing?
Again, I'm not trying to argue that I/we should be able to use modified ham gear on other bands, but rather just trying to better understand the why of the regulations.
The reason that radios need to be certified for Part 90 for public service bands is to be sure the radio does not put out spurious emissions. Ham radio gear is designed by the manufacturer to only be used in the ham bands. The circuits and final output is designed to only be used within a certain spread of frequencies. When you start using frequencies that the radio isn't designed for there are unknown issues. Out of band, spurious emissions can come from the radio on frequencies other than the one you're transmitting on. Your radio display may say 155.000 MHz but you could be putting out several watts of power on 158.000 MHz, or 138.000 or 154.500, or anywhere else, which could cause intereference to other users and services. The Part 90 certification ensures that the radio is up to specs within the designed frequencies and ensures that the radio isn't causing harmful interference.
The Wouxun and Baofeng radios are technically Part 90 radios that are also marketed as ham rigs. No other ham gear (that I know of) has Part 90 or Part 95 acceptance.
