KD8USW
Thinking it might be fun to invest in a new scanner. I've got a couple scanners but they are conventional style so I think I'm probably missing a lot with them. I live right on the Charleston/South Charleston city limits so hearing what goes on in both cities (Police, Fire, EMS) is a primary interest. I've never messed with a trunked scanner but have done a little reading so I think with a little help I should be able to figure things out ok, realizing it is probably a little more complex than programming my 2 meter handhelds. Have some questions.
1. How much traffic in the county is on trunked systems vs conventional?
2. How much traffic is not covered on the Kan Co. broadcastify feed?
3. It appears WV SIRN is the primary trunked system in the county, is a Phase 1 trunked scanner sufficient for the foreseeable future or does it make sense to go ahead and invest in a Phase 2 capable scanner?
4. What percentage of traffic available on WV SIRN in Kan Co is encrypted?
I'm trying to decide obviously how much more traffic will be available with this new scanner. If it is significant, I won't feel too bad about buying some higher budget equipment. Or would maybe well kept used equipment easily do the job? Obviously the likelihood of Phase 2 in the nearer future will play a large role in my decision (obviously I don't want to buy new Phase 1 equipment if it will be soon obsolete, new Phase 2 or used Phase 1 will make better sense).
Anxiously await whatever information and advice you can provide.
THANKS!
Monty
THANKS!
Monty
