Hey! Long time scanner enthusiast, and prior and returning user of Unitrunker. After using Trunk88 for years, and now investing in RTL-SDR I am back to Unitrunker. So neat that on a multi-site trunking system that you can monitor more than one control channel! So cool! Something Trunk88 doesn't have (though it does support RTL-SDR)
So Kudos to Unitrunker! Very impressed.
I know the subject of "holding" on a talkgroup has been brought up numerous times, and some great ideas many years ago were being considered. The current Voice Receiver hold appears to work slightly, but not really a "soft hold" which allows other traffic to be played while waiting for the channel to come live again
What my idea is would be a "delay" before jumping to another talkgroup of equal or lesser priority. Higher priority talk groups would still interrupt, but given communications on multiple channels of the same priority, it would be nice if we could set a "delay factor" before abandoning waiting for a response and getting new traffic.
Trunk88 does both of these function quite well, and it is well documented how it works. The current Hold Logic appears to "jump around" and get confused when a held talkgroup is on multiple sites that are monitored by multiple VCO's. Some work is probably required now with multiple control sources and audio output
F1: Hold on current comm
- If you press F1 while the voice scanner is tuned to a comm,
TRUNK88 will hold on that group call, private call or
interconnect until you release the hold. If no trunk traffic
is being monitored when F1 is pressed, TRUNK88 holds on the
last monitored trunked comm. [Similar to Unitrunker Pause]
Pressing F1 again while holding on a comm toggles between
hard (only tune to held comm) and soft (tune to other comms
while held comm is inactive) hold modes.
F2: Scan / release hold
- The F2 key logic is similar to a scanner's SCAN key.
If TRUNK88 is holding on a comm, pressing F2 will release the hold,
but does not force the voice scanner off that comm if it is
currently active (unless a higher priority comm is also active)
If TRUNK88 is NOT holding on a comm when F2 is pressed,
any currently monitored comm is effectively locked out briefly
while TRUNK88 looks for other comms to tune to. [Same Unitrunker "Skip"]
- F3: Toggle talkgroup delay mode
- This hotkey enables and disables the TG Delay Time hold timer.
When the timer is enabled, TRUNK88 implements a hold delay at
the end of every voice comm
When the timer is disabled, TRUNK88 does not implement a delay
at the end of every comm,
