boxcom
I've noticed that since my scanner has returned from Uniden with the Clock issue that my scanner will run for a while and freeze up. It appears that the unit is stopped on a channel with an open carrier, but nothing is flashing to indicate that the unit is stopped on a channel while in scan mode. There is noa audio, evenif someone is talking. The scanner would not respond to the push of any button, or adjustment to volume or squelch. I turned the unit off, and it stays on and stuck on the channel for well over a 1/2 minute. I actually had to unplug the unit for it to shut off. After re-powering up it runs normal, but after a while will freeze up again. It could be 15 minutes later or more. Anyone else have this issue? Is there a firmware update to fix this?
