Minitor V (5) amplified charger question
EngineCo8
KQ4CUD
Newinton, VA
OK so after a quick search on here I couldn't find an answer, so here it goes. Can someone please explain the lights on the amplified charger, right now when I put my pager in the charger the light blinks red quickly and in setsome of 3 (or 4 not 100% sure how many times it blinks I just know it is patterns of quick flashes pause quick flashes pause....etc). It just started doing this today and I can't seemake to find an answer anywhere on my own. So any help is greatly appreciated. Thank you.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Here is a link to the charger/amp manual for your future needs.
https://drive.google.com/open?id=0B3k529wkRVv1MHNEVnVHeDQxSms
The flashing red is Pre-charge state. If it never goes solid red that means it's not charging. It realizes the pager is there but doesn't charge. It's probably dirty contacts which is quite common with the V. Clean the contacts and try it again.
Let us know how it goes.
jdeverett
Venice, FL
Try re-seating the pager in the charger. Check to make sure you have a good battery, blinking red could mean a bad battery or not a compatible battery to the charger. If you are using a non Motorola battery, generic as an example. Check to see if the contacts are clean on both pager and amplified charger. Last disconnect the power to the amplifier for a few seconds, along with trying a different battery on the pager.
jdeverett
Venice, FL
SteveC0625...sorry for basically the same answer, when I posted your post was not up yet.
