Used to have no problem monitoring public safety on the Pinellas P25 system using a Home Patrol 1 and, most recently, a BCD536HP. Started missing talk group transmissions from time to time, then more frequently, now very frequently. Confirmed correct control channel and talkgroup activity with Unitrunker.
Just received a new Home Patrol 2 and - surprisingly - behavior is similar... Sometimes transmissions are received fine; Sometimes the scanner stops on a talk group but no audio is heard (or audio is broken); Sometimes Unitrunker indicates talkgroup activity, but one or the other scanners (sometimes both) miss the entire talkgroup exchange.
External antenna vs suppied antenna makes no big difference (I can see site 5 from my residence). Actually, the external antenna might even be worse! Thinking that the signal might be TOO strong, I tried attenuation on both scanners... the signal indicator shows less signal but behavior seems no different.
I've checked all of the settings in the respective Sentinel versions and all appears OK. I've even reloaded the P25 system from the main database (rather than my Favorites list) and no difference is noted.
Has something changed? All suggestions appreciated.
- John
- John
