CB Recommendations
SB-Wi
Eastern Dane Co
We're moving to CB's at work from our UHF LMR radios and looking for similar quality mobiles and portables as well as a base setup. We only need close range reception on job sites and at a quarry with 80 ft vertical rock walls. We also need "short" antennas to mount on dump trucks and heavy equipment that can hold up to tree branches and other overhead obstructions. What are your thoughts?
IdleMonitor
The Ottawa Valley - Eastern Ontario
As someone who works in a scale shack in a quarry, we use very simple radios. Uniden Pro510 XL mobile radio, and Wilson 500 antennas. Even on the shack that's what I use to talk to our drivers in and around the pit.
While I do get alot of interference on my radio in the shack I'm still able to talk to who I need to when I need to. The transmit on the one in the shack I'm impressed with as I've heard the distance on my own mobile, but the receive is horrible. Probably due to either the scales or a charger of some sort. I haven't been able to figure it out yet.
Just make sure they stay somewhat clean (especially the speaker and microphones) in the environment you want to use it in and they should be just fine.
Project25_MASTR
Millennial Graying OBT Guy
Texas
You want to stay in UHF for that and not migrate down to HF. If you are used to commercial FM gear…only CBs up to par on quality are those from GME which doesn't have a US option.
Hard to beat a Larsen NMO27 for CB if you have a ground plane…it's a Public Safety grade low band antenna.
Portable CB tech has yet to come out of the 1970's (so they're still the size of bricks).
80 ft on properly setup CBs…won't work due to being too close.
robertmac
Certainly won't find a shorter antenna than a UHF, especially one that might be effective for CB. Shouting would be more effective, second would be a bull horn.
gewecke
Banned
Illinois
STAY with Uhf, don't downgrade to cb's. That would be like going back to dial up from broadband internet! 73, n9zas
freqs
warren michigan
I drive a Roll Off Truck In the landfill they use a mix ox Antennas Mag Mount and mounted .Some ideas The Scale house uses either a Antron 99 or the like Some mount a Mag Mount on top of the shack .The equipment will mount a mag on top like a Wilson 500.They also mount them on the grab handles .We use CB so we can talk to each other and outside companies that use the landfill.
SB-Wi
Eastern Dane Co
Thanks for the input. I was hesitant to the switch at first knowing the differences between LMR and CB but most trucks that come into the quarry are not ours and can't communicate with the scale or loader. We only have a dozen UHF radios for the quarry and trucks and the guys out on jobs want to be able to talk to the trucks and each other too. I was asking for what equipment was durable and performed well under these conditions. Should I recommend a midrange model or will a basic one be as good? I'll hold on to the commercial gear until the CBs are fully tested.
Project25_MASTR
Texas
Sounds like what is really needed is a dispatch setup where only the people who need (not want) to talk to trucks have CBs. The reason I say that, your handheld guys will do nothing but complain about having to carry hand held CBs as they are easily 3-4 times the size of a modern hand held radio (think 1970's Motorola for a size comparison).
