RadShackFan
I live about 19 miles from the nearest tower associated with my local city/county P25 sysytem. Using the radio shack 800 antenna, I barely picked up the system. I switched to a magnetic (Wilson) cell phone antenna, sitting on a small cookie sheet (ground plane) and on top of a tall book case. This improved the signal to 2 bars on my GRE 800, but I still had a lot of the digital garble in the traffic.
I took a chance and bought a Tram/Brownig 800mhz yagi from the antenna farm:
http://www.theantennafarm.com/catalog/tram-browning-br-6386-3585.html
Mounted the antenna in the attic, fed with 25' of quad shield RG6. The P25 system now comes in at full scale with absolutely no garble. A side benefit is another P25 system, Alabama First Responder Network, is also coming in at the same level even though its only tower is 90 degrees to the yagi @ 14 miles and in the 700mhz area.
Anyone needing a good directional antenna should consider this antenna.
