Kenwood TK-941 - Volume Problem
skyler440
Denver, CO
I have a few kenwood TK-941 radios. One of these radios has a very strange volume issue. When I power up the device, the volume automatically resets to 100 % and you hear the ear piercing "BEEEP!"
So I looked around in the software to see if there was any option for this, but I could not find anything. The only setting that I did find was the "Minimum Volume". Changing this value did not do anything , I changed the minimum volume to "0" but the problem still persists. (I confirmed this by programming the other radios with the same code, and not having the issue)
Does anybody know of any fix to this problem? Perhaps a jumper in the radio, or something I am missing in software?
I also could not change TX power, Deviation, Squelch, etc. on the front panel (the service menu was brought up by pressing group down and power at the same time). The values would not save.
Besides that, the radio works fine. Frequencies or "fcc codes" are programmed into the radio without a problem.
kayn1n32008
ØÆSØ
Sector 001
Most ham stuff, outside of 900MHz and digital modes are +/-5.0KHz deviation. As for power, it is likely only changeable via software, on a per channel basis, or via a dedicated button assigned in software.
skyler440
Denver, CO
Can't find anything on a channel basis, but I did find my problem. I can't fix the speaker issue, but I did not program the power in right. I needed to press the "AUX" key.
Well there is no ham equipment for 900MHz, and all of the other modified ham gear I have is 2.5KHz. One of them actually lets me select between 2.5, 4, and 5.
