Chester Co 160.1850 Data Locking Up Channel
phillyfires
Pa
I am wondering if anyone could help me with scanning Chester County.
My office is in Malvern, PA and we monitor Chester Co on a Uniden 996T. Everyday usually in the afternoon the Dispatch Channel 160. 1850 locks up with a data signal.
According to RR a PL tone is not used and a new APCO-25 scanner is not in the budget.
If anyone could help me fix this problem it would be greatly appreciated.
W3DMV
Gettysburg, Pa
Surprised no one offered anything yet. There are many active contributors on here from
Chester Co and someone will drop by.
I live in Gettysburg and the Chester Co 160.185 is very loud here even on my mobile
driving around town.
I assume the interference is a real station and not crud from something in your office
or neighborhood.
The only station licensed within 50 miles of Malvern is Ward Fuel Co in Hamilton, N.J. They have a
license for NFM only and nothing digital.
If the frequency in question is the only one monitored, then you might try reducing the size
of your antenna to eliminate the offending signal. If there are other channels programmed,
requiring the antenna in use, set the attenuator on for the frequency in question which could
help reduce the level of the other station....
Good luck....
phillyfires
Pa
i will try using a rubber ducky antenna and the attenuator tomorrow.
thank you very much
u2brent
OAMPT
KRWDPAXKRS1
Railroad Channel 005
The offending signal may be a nearby paging/medical system or even a channel used by the railroad in the Malvern area. Rubber Ducky may help. I'd try the attenuation option first.
Good Luck!
wtp
Port Charlotte FL
the 996T
that radio does do digital.
so I guess try one of the P-25 channels.
just checked and it also had data skip.
phillyfires
Pa
worked
Just did a trial run with the attenuation on and so far so good. No data signal. You as I listen before turning th Attenuation on, it sounded like a control channel. But who knows.
Thanks all for the suggestions. I will monitor during the evening rush with the scanner and online and see if I am missing anything on the scanner.
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
u2brent
OAMPT
KRWDPAXKRS1
Interesting!
I always wondered where those irritating data bursts/pulses were coming from..
CommJunkie
FM19gt
The QRM in question is from a DMR Cap+ system run by North Penn School District (160.1775 on site 1)
ULS License - Industrial/Business Pool, Trunked License - WPHG723 - NORTH PENN SCHOOL DISTRICT
You'll also hear the same data noise on Chester County West Fire 159.600. Same system, same site
There's really no way to eliminate it without enabling the attenuator or I guess removing the antenna alltogether if you're close enough to a Chester County repeater
This is why they moved 159.735 to East Fire and 159.600 to West Fire
Now I get a dial-up modem sound on 159.600 sometimes in Southern Chester County. No idea where it's coming from.
