I have an issue and hopefully you can help me resolve it. I have Winamp and love it when it comes to listening to the feeds.
I have selects the Multiple Instances option and I still can open only one feed at a time. Can someone explain how I can have multiple feeds open and operating at one time?
Thank you in advance.
John
You must open WinAMP for EACH instance.
You can see that in the images in the post above.
In the bottom screen capture, I started WinAMP eight times and OPENED the URL for each feed.
(You may have to create a new 'Shortcut' and use that to open the instances if what you are using now only starts one.)
Then, you can RIGHT click on the PLAY button, and select "OPEN URL".
Paste or type the URL you want to play.
Then: Click on "OPEN"
After the first time you type or paste a URL there, it will be available in that drop down box in the future.
In WinAMP
Right click on the top of the WinAMP window
Select: Options
Then: Preferences
See the first image below:
Then check the box to "Allow Multiple Instances"
That will allow you to start as many WinAMP sessions as you want and your computer horsepower can handle.
You can also have WinAMP display any text tags that are streamed.
See the second image below.
"Read the metadata"
Rich
To allow multiple instances of WinAMP:
To see text tags:
