I just got a Pro-197 and am a bit confused by the programming. I have programmed one before, but may have done it wrong. The previous time I did it manually and deleted talk groups that I did not want as they came up. Is it recommended to get the software to make it easier to do the programming and do I have to enter the frequencies multiple times with each talkgroup that I want to listen to? If this is the case, I will have dozens of frequencies and hundreds of talkgroups to enter under each one. This seems a bit excessive if so. Any help would be appreciated.
If you want a "refresher" on some of the details about your scanner and how to program it, along with some information about Trunked Radio Systems, the RadioReference Wiki has some articles to get you started.
If you go to the
RR Wiki Home page, on the top of the right column is a blue-background box with links for Newcomers. Even though you are not brand-new at this, these might be helpful anyway. Some other RR Wiki pages that might be useful are
Trunking Basics and
Trunked Radio Systems.
If you are looking for programming information for the scanner itself, the
Programming Your Radio Shack Scanner wiki page lists many models including the 197. The
Pro-197 RR Wiki page lists the following links for owner's manuals:
Easier To Read Manual for the 197 etc.
Radio Shack manual on manual-hub.com (.pdf)
I agree with earlier comments...
Yes, manual programming can be a valuable skill, both to learn the scanner, and to update the scanner when a computer is not available.
And, a computer, with programming cable, and your preferred software, will make scanner-programming much easier long-term.
(Using a computer can also help you keep your work (by saving the file) so that you can reload that file if the scanner gets "reset/cleared" "accidentally". If you only program manually, you might be more likely to lose your work if the scanner gets reset.)
Hope this helps,
