- Joined
- Mar 17, 2013
- Messages
- 26
Hello all. I'm currently monitoring a motorola P25 CQPSK trunking system with two RTL-SDR dongles, unitrunker, and virtual audio cable piping output to DSD+ on windows 7.
I was only getting around 30% decode rate with the whip antenna that came with the dongles, so I built a 10 element 850Mhz yagi in the hopes of improving that. I've read that decode errors can be caused by interference between slightly out of sync signals from multiple simulcast towers, so I thought that a directional antenna would help reduce the interference. The yagi is surprisingly good for an hour of work and a few bits of copper tubing, and has increased my decode rate to around 75%. Unfortunately, it turns out that one tower is about northwest of me, and the next one is directly northwest of that, so I can't really lock onto a single tower.
I've heard that OP25 has better error correction algorithms than DSD+, and I'm pretty experienced with linux, so eventually I'll head that direction. OP25/GNUradio is a bigger project than I have time for at the moment though, and I think unitrunker is great, so I'm hoping someone can provide some suggestions for unitrunker or DSD+ fine tuning to help reduce the errors.
If it would help to look at the geography, this is the system I'm monitoring: https://www.radioreference.com/apps/db/?action=siteMap&sid=2361&type=rr
My location is about directly east of "Boys Town" on the map.
