- Joined
- Mar 17, 2013
- Messages
- 26
Hello All. I recently built a 10 element 850Mhz yagi antenna: https://goo.gl/photos/gZojPF8eThPxLsQF6
I used this site for the measurements: Martin E. Meserve - K7MEM - VHF/UHF Yagi Antenna Design
I also used the feeding method on the same page (1/2 wavelength of coax bridge on the folded dipole).
The reason I built the antenna was to try to block out some interference from several simulcast towers. I was hoping a directional antenna would help me isolate a single tower. That didn't happen for geographic reasons... but that's another thread.
Otherwise it seems to work pretty well, if I pan it around in the direction of a control tower, I get very strong reception within about 15-20deg.
I have just a couple of questions:
How accurate does the positioning of the parasitic elements need to be? I'm sure the spacing is exact to within 1-2mm, but the elements aren't exactly square to each other. They are also slighly skewed in the vertical plane (horizontal in the picture). What kind of tolerance should I be shooting for here?
How can I quantitatively test the performance of the antenna? Right now I'm just panning it around and watching what happens in SDR#. It would be nice to have real data to see if my tweaking is making the situation better or worse.
