I thought about that! I remember reading about paralleling cables, and it would not have been too, too bad with only 2 paper clips (I can imagine your 4!), but in the end, I ordered the 35 and 75 ohm cables from the Wire Man. The only thing I could find locally for 75 ohm cable had a foil layer under the braid, and I didn't want to induce noise. The 35 ohm cable has a very thick center conductor that I had to mill down to fit the RF Industries crimp connectors. The 75 ohm cables have a very thin center conductor that I'm worried about flexion breakage. The commercial cables have a tie-point shielding device and then are potted in epoxy. Every time I've goo'ed up a cable, I've changed its characteristics, so I just went with connectors. Before I permanently put this up, I'll probably add a layer of pitch tape over the center T and look into some kind of goo that won't change the dielectric properties of the cable. Probably take Prcguy's advice on silicone grease.
I made a spreadsheet with the formulas to calculate optimal dimensions, factoring in Vf. I can send it out if anyone wants it (my PM fills up, so use email). The Wire Man cable seems to fit the optimum calculated inter-element spacing just right considering the center frequency between transmit and receive. Their RG-83 and RG-11 both have a Vf of 0.66.
I just had a QSO with one of the local guys who has a spectrum analyzer (I haven't bought one yet, although I tend to buy more test equipment than actual "stuff" for my projects). We're going to get together and take a look at the transmitter to see if it's clean.
It's only a hobby, right?
Hey Wyandotte - If you get a new harness from the manufacturer (you can buy one), make sure you specify exactly which frequency range you're using it for. A 2 meter harness will probably either up or downtilt the vertical beamwidth if you're using it on business or public safety frequencies and vice versa. I'd be happy to send you the spreadsheet and parts list (that I used, at least) if you think you want to take on the project of building your own.
