Bob132
In the Owners manual it mentions not unplugging the AC power supply until the scanner has been shut off. Does this also apply to 12 volt power? On my previous scanner I installed a toggle switch on the driver side of my vehicle so that I could leave the scanner turned on and volume set to a desired level and not have to lean over to the passenger side of the vehicle to power up or set the volume.I would use the toggle switch to turn the scanner on and off and it worked great. I also noticed that if the BCD536HP is on when I start the vehicle , it reboots as if I had turned the power at the scanner off and then on again (as does the toggle switch). Can anyone tell me if these things could damage the scanner, and if so what I might do to remedy the situation.
At this time I have bypassed the toggle switch and the scanner is connected to 12 volts at the battery, however the scanner when turned on is still rebooting when I start the vehicle. I will leave it this way until I hear something different from someone that knows more about this scanner then I do.
Thanks in advance,
Bob
Thanks in advance,
Bob
