What antenna is this?
N5JMC
Arkansas
Can anyone help with what antenna this is? It was on a local county sheriff car and the only antenna. They're on P25. I've been wanting to get an antenna on my truck to pick up p25 better on my scanner and would much rather have this small one if possible.
N5JMC
Arkansas
Is it good for picking up? Should u get that or a longer antenna to pick up digital on my scanner?
902
Downsouthsomewhere
Depends. I mean, it works for them (obviously) but a scanner has a much wider receiver. Too much gain and you might get clobbered when you pass a cellular site or you might pick up multiple simulcast sites and get distortion. Not enough gain and you might have a noisy signal. Most people just go with one of the 3 inch spikes. They work about as well as the "low profile."
902
Downsouthsomewhere
I probably should say that digital signals don't need a "digital antenna." That was a gimmick the old television repairmen used to use for color TV to sell more "color TV antennas" and it seems to have popped up in digital times. So, you don't need anything special to hear a digital signal, just something that's resonant. But beyond that depends on where you are in relation to what you're trying to listen to.
902
Downsouthsomewhere
What are the 3 inch antennas you're referring to? Are they good for 800 p25?
I just sent you a link to a description in the last post. They should be fine for 800 P25 in most cases. I don't want to be confusing, but a scanner will work on just about anything, though.
N5JMC
Arkansas
Yeah it works pretty good but just want an external antenna to get better reception in areas I don't that good now.
Thank you very much!
