Minitor V Microphonics
cmjonesinc
I hope someone can answer as well. I have three v's but only one does it and it's super annoying.
BlueDevil
WA
I have tired putting various amount of foam between the speaker and the receiver/rest of the circuitry without much success. Maybe slight improvement.
BlueDevil
WA
I have tried various different thickness foam. What type of density or how porous is the foam you have used?
BlueDevil
WA
I am putting the foam in the right place... Right? Between the speaker and the circuit board? Obviously there is no foam in this picture other than the small piece of factory foam on silver shield.
dixie729
Daviess Co., KY
When I get home I'll take look at the thickness I used.
Yes this is the correct place.
That aluminum plate on the circuit board side. Cover that entire plate with foam
Sent from my XT1097
BlueDevil
WA
Could this broken screw mount cause the front and back cover to become just loose enough to cause the problem?
dixie729
Daviess Co., KY
Highly unlikely.
The audio amp is picking up the speaker's vibration and causing the feedback. Hints why it does it when the volume is increased
Sent from my XT1097
Wiregeek
I wonder if some high density foam - I'm thinking dynamat, or even mouse pad rubber, would help.
BlueDevil
WA
It looks like the manufacturer (Unication) uses a fairly thin piece of high density foam as seen in the picture. Maybe just double the width of that?
dixie729
Daviess Co., KY
I'd start with double and try it.
How much of the area did you cover?
I can't find my torque bit to get the case off right now..lol
Sent from my XT1097
dixie729
Daviess Co., KY
I wouldn't use too much, the housing may not seal correctly. Make sure you get a good seal all around the housing so water doesn't ruin the internals.
Sent from my XT1097
dixie729
Daviess Co., KY
This obviously isn't the same pager but I put rubber or foam (which ever) In the purple areas.
The blue arrow points to the intentions the speaker left on the factory rubber if you can see it or not.
Hope this helps.
Sent from my XT1097
