I don't need to check the wiki, 'cause I wrote it :.>>
I didn't say that ARC250 won't work with the 796 because, as Gommert says, it does - however, it can't work with the 996 due to the memory architecture. I know ARC996 can accept data in several formats, but I don't believe it could down-grade data from a DMA scanner to a standard banked scanner
If ProScan can't downgrade the data, your only option is to dump the contents of the 996 into a standard csv (comma separated values) file, manipulate it in Excel or similar (there are several free open source options here), then use a data import function that can use a csv file as input. I *think* ARC250 could accept this, but Gommert knows best :.>> Mike
