XTL5000 W series to 05
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
I have a mid power dash xtl5000 W4 configured. What is needed to turn it into a 05 remote mount? I am going to buy the parts needed off the bay.
Now before anyone goes ranting about needing software or illegal "depot", it will be sent off to depot/ M for flashing after I buy my parts for cheaper then MSRP.
rescue161
KE4FHH
Hubert, NC
No depot needed. You use the CPS to change the control head. Your version of firmware may be needed updated as older firmware did not support the O5 heads.
I don't have the part numbers handy, but they are easily found on Ebay.
SirJ
Well that's good to know, will save me a little but of money there. Do you know if the astro spectra remote kit will work with a W series xtl5000? I have two w4 xtl5000s.
I would like to make one into a remote 05 and remote w4.
rescue161
KE4FHH
Hubert, NC
It will work, but not for an O-series head. They use the smaller cable. The flexes are very different between Astro and XTL radios.
SirJ
Yeah I understand I can use the astro spectra cable if I remote the w4.
I know the 03/05 use that round funny plug.... Don't know what it's called. But okay cool, can anyone else confirm this that way I don't go smoking my radio *yikes*
TLF82
Texas
The round mic connector is called a GCAI connector.
To go to to a W to an O you need a the correct flex, bridge, and the O5 head. Before you move to to the new head read the radio and change the control head in CPS and program the radio. Power it down and swap the heads. Be careful and make sure you are grounded. XTLs are very static sensitive.
If you need firmware to be flashed, I have an ibutton and can help you out for a small fee. Email me at: k 5 t l f 1 at gmail dot com.
SirJ
I was able to use the astro spectra dash kit on the w4 head, but the other piece with the two serial ports 24pin does not plug into the base of the xtl5000. Not sure if there is a special piece of ribbon needed to something.... The dash mount 05 turned out great. :/ bummed out about the w4 tho.
Looks like to use a astro spectra remote kit on a w series xtl5000 this part is needed: HLN6883 now this is just guessing that that kit includes the astro spectra 2x 24pin plate and a special ribbon. Where can I buy this that's not going to cost me as much as the radio? A simple Google search hasn't yielded much
cmdrwill
So Cali
I think you meant to say 25 pin DB connectors, which the Spectra and Astro Spectra's use. And yes they are out there for the XTL with the ribbon connector.
SirJ
Yes that's what I ment. It's been a long day.
I thought eBay was a place for parts for these but there are zero parts for W series XTL's. I seller sold a pair of what I need for 50 dollars, not sure if that is a good deal. I could imagine what I need is over $100 which means the w series dash stays a dash configuration until a kit, or parts appear on there or a forum.
SirJ
By chance do you recall where to change the head type? When I click on the tree branch that says: control head it just shows a w4 head...
TLF82
Texas
I'm not in front of my computer right now, but it's a drop down menu on the tabs on the top of CPS to change the control head.
SirJ
From what I gather online, I change radio control head type via CPS drop down menu, write to radio. power off swap to 05 head and power on and I should be G2G? If an error / maint mode appears then head did not sync right and will have to run sync process or use a CVN file to upgrade head? Radio is already at the last / latest firmware from MOL. I keeping the radio a Dash mount I am not Interested in remote mount at this time.
TLF82
Texas
You are correct.
SirJ
Just wanted to thanks those who helped me out, I successfully have a 05 xtl5000 in UHF. The sync process via CPS was super easy.
zacabo
FL
I'm looking to do the same with my XTL 5000's. What parts are need to accomplish this?
phillydjdan
I'm looking for the FIRST version it supported. I think its pretty safe to assume it was way before r20...
ResQguy
Meh
7/28/2005 Host R06.01.00 DSP R06.00.00 CPS R06.00.00
Introduction of O5 Control Head for XTL 5000 mobile radios
Also, it's an O series (Odyssey) head not a 0 (Zero).
