Thanks for the reply. Up until now I never have seen the St. Louis County Police or any other users of SLATER using encryption. I guess my question was really if the rumors I have been hearing about using encryption all the time were true.
I am using the Uniden HomePatrol-2 scanner with the extreme upgrade. The only department I have seen using encryption is the St. Louis City Metro Police.
Again, thanks for the reply, 73 Rich
You need an older radio that will work with Pro96com.
Slater has many very active encrypted TGs for the users. Many of these TGs have been in use since the system was first put on the air.
If you do have one of the radios that Pro96com supports, hook it up. You will be surprised at the amount of encrypted traffic there is on Slater!
Any TG that is in the 556xx and up range is encrypted on Slater in St Louis County.
You may see some of these flash on your HP-2 display for a very short period if you are in ID Search mode and the 556xx TG is not already programmed and avoided in your Slater favorite list.
You will not hear any audio though as that TG range is fully encrypted.
The 558xx TG range is used by fire for encrypted channels.
All Muni's in STL County should have at least one TG they can use in the 556xx range. They are called Support channels in the users radios but are usually tagged as Law TAC here in the DB. And they will show an E in the Mode column here.
The County PD precincts have several of these encrypted TGs for their use as well. Again, they are in the 556xx range for PD and 558xx for fire.
