I have some UHF Tait handhelds that have no external power solution to them other than charging. The charging circuits don't provide power for transmitting. There are times we need to adapt the handheld to "mobile" aircraft solution since the pilot can't use a "literal" hand held radio and fly at the same time, and a battery just doesn't cut it for large jobs (and pilots can barely remember their lunch let alone managing batteries.)
An idea I had was to rip out the guts of a battery pack and simply use the shell to externally apply the proper voltage and current to the leads in the shell that contact the radio. I've seen other radio manufacturers do this but not sure if I'm missing something like filtering etc. (which we can do on the incoming power if needed). An example I'm talking about is Battery Eliminator for KG-UV9D [BTE-9] - $15.99
Edit: I'm seeing names for these like Battery Eliminators or Dummy Batteries.
