I have my A and B tone codes already programmed into the software , I just need to know witch option to assign the function key that will enable the radio to set pages off either by hitting one of the function keys or the PTT. I went ahead and set one of my function keys as 2 tone, another one as call alert and I believe one as select call alert. Whichever one of those three it is, I would appreciate you letting me know so I can get rid of the other two options and assign something else to those two function keys. Also, regarding the second half of my earlier question, for my PL tones for Rx/Tx, after I entered in the frequency there is a collum that says decode and encode. I am assuming the decode column is the Rx pl tone or DPL tone that the radio needs to hear from a dispatch console or a another handheld radio that has the same PL / DPL., and not CSQ, open carrier, and the encode column I think would be for the individual radio Tx itself, so when I hit the PTT,my radio will transmit w/ the 146.2 pl tone code, but when I recieve, I have the decode collum set to none( assuming that is the Rx side of it). My example I'm going to use is our county fire frequency(Guthrie County, IA fire page, 154.2350 w/a pl of 146.2). The county added that PL tone when we switch to narrow band,, prior to narrowband, everything was open carrier squelch CSQ, and some other neighboring agencies that we monitor have also added pl tone codes, so I just want to make sure I programmed it correctly with the frequencies. For transmitting, I programmed the 146.2, under the encode, assumine, again, the encode programming collum is for Tx... if my assumption is correct, when I hit the PTT button, it will open up the dispatch consoles radio because it's connecting with the 146.2 pl, but under the decode column, I left it set to none, or CSQ, as some other people would call it. From what I understand I really don't need any encode pl/dpl on the recieve(Rx) side of things, it's just the Tx pl code I would program, if the channel or agency I'm wanting to talk to has a PL / DPL tone code installed in their radio system . This software doesn't say Tx or Rx, like my Motorola programming software does for my Motorola radios. I guess to make this as short and sweet as I possibly can, if I haven't already confused you or bored you to death reading all of this, I am assuming the decode is the same as Rx,, and the decode is the Tx. I am very sorry for making these lengthy threads. Again, as I stated in my original post, the Kenwood stuff is all brand new to me, and I'm hoping with time, just like the Motorola programming software, I will get better with this as time goes. I really appreciate everybody's patience and input. I will try and not post too many more questions, I just know and trust that this website is the best website in my opinion to get advice for programming radios, or for that matter, advice about anything regarding radios(two way receivers/transmitters, police scanners, and so on. Again I will try and not post too many more post's about this, I just want to make sure I have it all ready to go, that way when my radio gets here, all I have to do is plug my programming cable into the com port and program the radio. I have already gone into the software which I also installed on my Windows 98 DOS laptop, which is the laptop I use to program all of my Paging & radio stuff for the dept and programmed everything for the Kenwood radio when it gets here. My main features that I want is for the radio to set off our tones, to be alerted like a pager in silent mode until our pager tones are transmitted, and also be alerted when our tones are transmitted, whether I am monitoring the channel alone, or in scan mode. I got the priority channel thing figured out I think, I am using the option under the priority channel options drop-down menu "select", meaning with whatever channel I am on using the top rotating channel selector knob, next to the on and off power knob., I set it to make the priority channel alert me w/a tone when radio traffic is transmitted on whatever channel I have the channel selector on during scan mode as my priority channel, it will make an alert noise. As a default I have the timing set to revert back to the priority channel every two seconds, just like my Motorola radios do when I am scanning and there is traffic that pops up on my priority channel while in scan mode. The other big deal was the nuisance delete, and I think I have got that figured out too, and all of this is from everyone's help on this website. If I have any more questions I know I can resort to you guys and gals. Hopefully there won't be too many more and I can get it figured out eventually. Any more advice or programming tips that you think I might like, please feel free to post them here, but right now my main concern is Rx, Tx codes put in the right place.
