on or off and orange it is.
Setting the Backlight
Press to turn on the backlight on and off.
1. Press Func and to view the Display/Charge menu.
2. From this menu, scroll to Set Backlight from the
submenus. Press SCROLL CONTROL.
3. Scroll to select one of the following settings:
• Always Off - Backlight is always off.
• Always On – Backlight is always on.
• On with Squelch - Backlight is on while squelch is open
and until delay expires.
• On with Keypress - Backlight is on for 10 seconds after
any key is pressed.
• Keypress+Squelch – Both above-mentioned "Squelch"
and "Keypress."
• < Back - Return to previous menu.
4. Press Pgm/E (or press SCROLL CONTROL) to save and
return to the previous menu. (Default = Always Off)
5. Press . Clr to exit.
Notes: If the backlight is set to Always On when is pressed,
the backlight is turned off and the backlight setting is then set to
Always Off.
If the backlight is set to Always Off when is pressed, the
backlight is turned on and the backlight setting is then set to
Always On.
