Best 2' - 3' Antenna
Best Short Antenna
  • Total voters
    11
SB-Wi
Eastern Dane Co
Yes, I want opinions on 24" to 36" mobile antennas.
I've only seen Solarcon A-110 and A-111 and TruckSpec TS-536 (RoadPro RP-550) for whips.
Fiberglass has many more options:
Firestik FL3-W
Wilson 305-482
K40 SF-200W
Francis 300-CB22W
TruckSpec TSPS-2W (RoadPro RPPS-2W)
All of the above brands except for FireStik are owned by DAS Companies, Inc. I'll probably stay away from TruckSpec/RoadPro unless someone speaks very highly of them.
gewecke
Banned
Illinois
Larsen Nmo27S would be my choice. :wink: 73, n9zas
Retroradio
Ontario
Wilson all the way for me. Although not a whip have run Wilson mag mounts on 11meters for a couple for decades and don't run anything else.
SB-Wi
Eastern Dane Co
geartow
I like the everhardt tiger antennas for fiberglass. We stock both 2 ft and 3 ft at work we break them a lot on the tow trucks . These are cheap $10 and work well for talking truck to truck for a couple.miles.
KC2GIU
Just my 2-cents.
Steel whip antennas hold up very well to icing as in ICE STORM conditions. Fiberglass will fatigue, crack or just break when driving around while it's encased in solid ice due to vibration or getting bumped.
If you don't live where ice storms happen, then fiberglass would work just fine.
TheSpaceMann
I actually have the lill' Will and it works very well. I have even used it on 10 meters mounted on an air conditioner from the inside of a hotel room, and I was able to make several contacts over 1,500 miles away on 25 Watts SSB!! :)
FiveFilter
My magnet-mount K30 made by K40 works well with about a 35-inch whip. It's about the same as the Wilson Lil Wil. I can get in my garage with it mounted on the trunk. Very convenient indeed.
BBB007
A 24" Firestick II (2) will work. These are tune-able from the top but most importantly usually need one or two 4" Steel Spring mounts underneath to tune properly for lowest VSWR. (shh, its a secret) The Spring Mount also helps the antenna rebound from tree impacts. So order a couple of those with the antenna.
Amazon.com : Firestik II FS-2BK 2 feet 300 Watt FS Series Tunable Tip CB Antenna - 1 Each - Black : Automotive Cb Radios And Scanners : Automotive
Amazon.com: LOT OF 2 (TWO) Firestik SS-3M Medium Duty Stainless Steel CB Radio Antenna Spring: Automotive
