I agree.
Take out the main TGs and you don't know if there is anyone talking. Stupid but I've heard lots of complaints about DMR-Marc and their conduct so.........
From what I've read its to avoid tying up channels but when I suggested using the built in trunked capability in the M radios to expand availability the reception to that idea was....less than enthusiastic, lets say.
Made sense to me though.
Many, dare I say most DMR users do not have /\/\ equipment, so trunking isn't a viable option even if the repeater owners wanted to spend >$10k for just one more repeater.
The "problem" isn't limited only to the DMR-MARC network either! The
same issue arises regardless of network. The actual problem is one of resource utilization!
Most folks just getting started on DMR do not understand that whenever they key up any wide-area talk group, they are actually keying up
every repeater actively monitoring that wide-area talk group!
In the case of Indiana Statewide on the Hoosier DMR Net, a single conversation will simultaneously key up 48 repeaters. Similarly, the Midwest talk group would key up nearly 400 repeaters!
Can you imagine how many repeaters are keyed up on North America, World Wide English or World Wide Global for just
one conversation??? While the precise number will always vary since repeaters come and go, may already be in use on another TG, and so forth, the potential number can be as much as several thousand!
Therefore, instead of making all wide-area talk groups PTT only - which effectively makes them completely useless - the real answer is to put a timer on the c-bridge that will absolutely limit usage to a fixed period of time of 2 minutes or less, and ensuring that there are at least a dozen or so PTT on demand TGs that are common to
all networks.
Then a hypothetical QSO might be:
Victor Echo 3 Mike Bravo Alpha, here is November 4 Golf India X-Ray.
N4GIX, VE3MBA here.
Mike, TAC310 seems to be vacant, can we QSY there?
QSL Bill, VE3MBA QSY TAC310
N4GIX QSY TAC310
