TRBO Group ID issue
jtech48
OVB
I'm currently monitoring a business that at the moment utilizes 3 TRBO repeaters, each repeater with its own frequency (UHF) but different color codes and time slots. All users of the repeaters transmit on the same Group ID of 1 on whatever channel they're assigned. I've programmed this system into an XPR6550 for RX only and receives fine my only problem is that regardless of which channel im listening to (i.e. Custodial) the screen always displays that its a Group Call from ADMIN. I've made sure that each channel's RX group list was programmed to it's perspective users. Does anyone know what steps I can take to remedy this, or if it can be done with all having the same Group Call number?
NotATechGuy
NotAMember
If I understand correctly you are seeing only one radio ID transmitting regardless of the radio. It is possible they never setup unique radio IDs and every radio has the same. This would be a major problem if trying to more than just group calls. I don't know how the 6550 is set to display radio IDs but in the 2.0 radios if there is no alias it displays the radio ID #.
jtech48
OVB
The radio ID's do show up, each one has it's own, as an example radios 1200-1250 use the Custodial repeater and the Custodians talk on that repeater with a group call of 1, Admin staff radios 1300-1350 use the Admin repeater with a group call of 1. Private calls are enabled.
NotATechGuy
NotAMember
1 of them is named Admin for the Admin channel but the other 2 are named different.
You mentioned the group ID is 1 for all. So if each group ID is 1 it's only going to display one name. No matter what channel you are on.
jtech48
OVB
That's what I wanted to confirm, thank you, you've answered my question
