and with everyone ****ting on the discone then what is the best antenna for my scanner???????? the one on the back of it ??????????
It would still help us if we knew a general idea where you were.... North Coast means different things to different people. Being able to know what's out there in your area can help suggest an antenna.
What is going to work "best" is:
1. something you can actually afford. This is why knowing what your budget is helps so much.
2. something designed to be resonate on the frequency ( or frequencies) you want to listen to.
3. something you can actually get outside and up high
In an "ideal" setup you'd have dedicated antennas on each band that actually exhibited some gain.
It would be connected to your radio with appropriately sized/spec'd feedline
Budget is important since there is little point in suggesting a system thats so far outside your budget that there isn't any reasonable way you can afford it. I could spec out a really nice system if you had a few thousand dollars to blow on this. If your budget is more in the $100 range, that's going to change things.
While a discone can be resonate on a very wide range of frequencies, it does this at the cost of antenna gain. To top it off they have a funky radiation pattern that makes them not always the best choice for transmitting. Again, a rusty nail can be tricked into working well with nearly any radio, but it's probably going to suck in most cases.
In many cases a dual or tri band amateur base antenna might be a better choice as it'll have some gain on useable frequencies. VHF and UHF is where a lot of the popular stuff is. If you need 700/800MHz you might chose a dedicated antenna for those bands. If you are trying to pick up a specific system/site, then a directional antenna might be a better choice.
A discone -can- be an excellent choice if you need to transmit and receive over a wide chunk of the VHF/UHF bands. It's not going to work great for anything, but will be passable on most. It's a good "single choice" antenna.
Really, though, check into a dual band amateur base antenna. They'll work well in many places and probably work OK on 700/800MHz.
And, if you are going to invest in an antenna, don't cut corners by using crappy feed line. If you use cheap cable you are going to severely cripple the system performance. You don't need to break the bank using high end hardline, but depending on the distance from your radio to the antenna there are a range of choices and costs. Knowing what the distances involved are really helps us make suggestions.
