You probably will if you make sure you aren't using a garbage mail service. If you are having trouble receiving the emails, the author states that you should get Gmail or Yahoo address because he hasn't had issues sending to those domains. Anything else might be hit/miss.
Otherwise, it goes without saying [and I'm sure you'll feel insulted at the suggestion because I probably would too], but you should check your spam folder or any folders that you specifically set up to trigger on specific message rules, just in case it ended up there.
m
