OKWIN P25 Phase II Control Channel Tulsa Site
peterjmag
Tulsa, OK
Just scanned control channels on the Tulsa site and heard both analog on 859.9375 and P25 Phase II on 856.1125 Sounds like the the P25 Phase II is not that far away. Save up your money and hope everything isn't encrypted.
wx5uif
Broken Arrow, OK
Thanks for the info. I just fired up Unitrunker and i am monitoring it.
Looks like 1939 (31024) Riverside dispatch, 1921 (30736) Mingo Valley dispatch and 723(Encrypted) is all so far I have showing up.
Frequencies Used so far are:
855.2125
855.2375
855.4625
855.7125
855.7375
856.1125
857.9375
858.9375
859.9375
I'll let this run a few days and see.
N5TWB
Sand Springs OK
Good news/bad news. The good news is I have a Home Patrol 2. The bad news is the scanner in the truck is a 996XT and it's installed in the dash in a DIN slot.
wx5uif
Broken Arrow, OK
I have a bcd996t with a tap for Unitrunker.
I also have a bcd536hp that I'll be building a favorites list to start watching this with.
plaws
E Hawkesbury Twp, ON
Were you able to actually use the DIN sleeve? I've got mine in my Subaru, but unfortunately, those cars use the ISO mounting scheme which is WAY more complicated.
If you have an actual sleeve, the good news is that a BCD536HP will pop right in! :lol:
(this comment sponsored by Uniden, makers of the radio I just suggested you buy)
N5TWB
Sand Springs OK
LOL -- now I just need to figure out the finances and I'll have it made.
wx5uif
Broken Arrow, OK
Getting TG 2241 (35856) today, Tulsa FD.
Looks like everything is fully P25p2, as my 996T will not pick it up, but my 536hp will.
plaws
No TDMA here to listen to on my 436 - what does the display show when a Phase 2 channel is being received?
wx5uif
Broken Arrow, OK
Dumb me put it in my 996t as a type2 system and not P25. I'm getting calls now, so it appears that TGs as of now are P1.
Freqed
I'm just a listener
Broken Arrow
Been listening this weekend and only getting the MV ID of 1921, also noting some Freqs, 855.7125, 855.4625, 855.7375 and 855.2125 showing up are those inputs? GSR-600.
nd5y
Wichita Falls, TX
What happened to 806-824 input and 851-869 output, with 45 MHz split?
Nothing happened. The whole 806-896 band is 90 MHz wide. The lower half is inputs and the upper half is outputs. The offset is still -45 MHz. The band has other users besides public safety trunked systems.
