steve-kc7byp
This Pro-2051 works great in picking up regular analog stations. In fact the Pro-2051 works 100 times better on the same station then the Terratec RTL dongle that I have. Like the NOAA weather radio in Richland, Wa on 162.45mhz. On the same wire antenna. The RTL dongle hears NOAA with a lot of background noise. When I can get the Pro-2051 onto the NOAA freq (I am having a problem in working the Pro-2051). The users guide that came with the Pro-2051 is useless. There is no way that I can see to put the scanner in a pure manual mode. I only stumbled 1 time on how to get the into the NOAA mode. It says "wxalt" next to the #1 button. Most scanners and ht's you use the func > #1 button to get into the weather mode. Not this scanner. Also I asked the seller if this scanner is digital and will it pick up the Proj 25 phase I and II. He said yes. Now after I got home and started searching online. I don't think it is a digital scanner. Also is there a better users manual online that I can download free?
Steve
Steve
