Ok I've been dealing with this issue off and on for a while now. I run a feed that carries a P25 system. It is locked on the system, no analog, and it pulls off a single site that is about 10 miles away LOS. There are a few other sites for this system (on different frequencies) that are between 30 and 40 miles away (it's basically one per county). The scanner is connected to a regular FM rooftop "cross loop" antenna where it normally pulls in 5 bars solid. But every now and then (more often during spring and summer, it's getting bad now) it'll have fits for days where the signal fades in and out, sometimes down to 1 or no bars and the T disappears..This causes it to miss tons of traffic. Changing to a mag mount ham whip pointed out the window (the scanner is basically in a faraday cage so anything indoor is out of the question) during these episodes does help to an extent, it doesn't go down to 0 but the control channel is still scratchy.
When I monitor the control channel during these periods, I hear the normal "diesel engine" sound, but there is static that fades in and out on top of the diesel as the signal meter goes up and down. I'm pretty sure that this has something to do with it not only being an omnidirectional antenna, but it's oriented horizontally. I think it's picking up reflections and maybe interference from something else. And for the record it performs much better going through a 6dB attenuator than it does connected directly to the feedline.
So I have a $150 gift certificate from ScannerMaster that is expiring soon. I had hoped to use it toward another scanner but damned if my money tree didn't die on me. They have 800MHz Yagis ranging from $42 to hundreds of dollars. Anyone care to recommend the best one for my situation? I have no idea what the gain on the antenna I'm using is, since it's not for 800MHz, but due to the fact that the transmitter is so close and I have to use an attenuator right now, I doubt gain is the issue. So what's the difference between the $42 10dB one, the $140 6dB one, and the $175 9dB one?
Rooftop Single-Band Antenna for Police Scanner Radios | ScannerMaster.com
