Md380 experimental firmware v2
Forts
Ontario, Canada
What do you mean by v2? It's a regularly updated project at this point (for example, it looks like there were changes made just 3 hours ago of this posting).
https://github.com/travisgoodspeed/md380tools
I compiled a version last Thursday and posted it to the files section of the MD-380 Yahoo group. Strangely enough the VA3XPR page showed a 'V2' file about 24 hours later... I assume this is what you are referring to?
Forts
Ontario, Canada
I just took a closer look at the latest changes... Basically there are two versions. A patched version of the stock firmware with 'pomiscuous' mode enabled that allows all talkgroup traffic to pass (group calls and private calls), also using a new font. Then there is an 'experimental' firmware that is a little more bleeding edge. It allows for promiscuous mode to be toggled on/off as well as some debug items etc. Right now it appears they are working on various menu items and things like adjust alert tone volume etc. Looks like they are trying to get a stable release ready for the Dayton hamvention.
seth21w
Somewhere monitoring the air.
Wasn't that fixed in the 2.034 stock firmware? I thought it was but I could be mistaken.
I think if you run the v1 experimental firmware it takes you back to previous stock firmware, either way its not correct with the experimental firmware version 1 i am kind of scared to mess with v2 if i cannot roll back.
Forts
Ontario, Canada
I've had no issues switching between versions. Think I flashed mine 3 times today alone (different versions of stock and experimental).
Where do you see the mis-spelling, in the FPP menu? If so it's been corrected in the version I'm currently running.
seth21w
it is showing in the program radio when i select repeater slot. and i am on 2.32 mcu version 1.0 hardware version thats what shows up in my programming software.
Forts
Ontario, Canada
Yeah unfortunately the experimental firmware doesn't change the version. # at all. It would be nice if they could implement that. Also I'm not sure why they are still working off of 2.032 vs 2.034. Oh well at least changes are being made!
Forts
Ontario, Canada
Here's a quick pic of the new font for those interested...
Forts
Ontario, Canada
I see someone posted a new file to the Yahoo group last night which is basically what you were looking for... The stock firmware with the spelling errors corrected and the new font applied.
RayAir
I just decided to install the exp firmware since I was willing to sacrifice the 380.
It does what is says it does. Private calls displaying on Con+ is nice.
After installing v2 I didn't notice any changes except the font style.
Any idea if the experimental firmware will allow the radio to unmute if MotoTRBO RAS is in use?
I don't have any local systems to test.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
You're actually able to monitor Con+ non-CCs and obtain actual audio? I've yet to be able to do that. And nobody could give me a confirmation that it even worked when monitoring Connect Plus TRBO systems.
Mike
tripleplay905
Summit Co, Ohio
Mike
Mike, do you have the TX and RX frequencies the same in the channel by chance? I couldn't get audio out of a Con+ system I wanted to monitor until I set the TX frequency to something other than the RX frequency.
03msc
RF is RF
The Natural State
So I'm going to be "that guy" and ask...how do you program the radio to basically receive all DMR traffic on a given frequency?
