Okay guys, I need some help. I want to be able to run my current feed off my Rasp Pi using the RTL SDR. I have gone through all the setup and its not working. I am not too familiar with linux so im probably missing something simple.
Now, I had setup at first using this: Raspberry Pi Broadcastify Image - The RadioReference Wiki
And I was able to run the feed with my current scanner without a problem.
Now I started to follow these directions to try to transition to running the feed with the RTL device:
I have followed the directions found here: Raspberry Pi RTL-SDR Broadcastify - The RadioReference Wiki
At this moment, I just want to get one feed up and online using this method, and then I am planning to add a second RTL and add a second feed this way too.
My feed is FM and scans 460.575, 460.525, 453.8, 453.9, 453.6, 453.5, and 460.6. When playing with the RTL on my laptop, I determined I needed 60 ppm. So if I understand correctly, this is what my code should be (Assuming I did everything correctly up to this point--I think)
/usr/local/bin/rtl_fm -d 0 -M fm -f 460.575M -f 460.525M -f 453.8M -f 453.9M -f 453.6M -f 453.5M -f 460.6M -p 60 -l 65 -g 40 -t 2 -E pad -s 12k |
/usr/bin/lame -r -s 12 --resample 22.05 -m m -b 16 --cbr --lowpass 4 - - |
/usr/bin/ezstream -c /etc/ezstream_bcfy.xml > /var/log/bcfy2.log 2>&1 &
Where does this code go? Let me know if I need to backup a step or two.
Thanks in advance for any help
