My 2001 Grand Marquis was getting a bit...rusted, to put it lightly. So I replaced it with a brand spanking new 2015 Forester last April. Got rear ended in June, but that's another story.
ANYWAYS, What's the best thing to do to a new car? Drill some holes, of course! Let's start with running power. There's a nice grommet under the front driver's side wheel well to push some chunky power cables through.
Almost looks OEM....
Radios are going to be mounted under the driver's side seat. There's 2 threaded posts embedded on the floor for mounting the OEM amp. I made an aluminum mounting bracket (sorry, no pics of that) that holds the two radios plus a RigRunner securely. No Velcro or double-sided tape on this install.
So with that out of the way, let's drill some holes in our brand new $20k+ vehicle! This is on the passenger side hood. I wanted a place where I could mount my Larsen 2/70 nmo and still be able to get into garages.
Coax is run over the driver's side to go through the same grommet that power was routed. There's a wonderful channel on the hood that runs pretty much completely across the engine bay, so the coax is mostly hidden from the engine.
Coax run through the same grommet as power.
Driver seat removed and trim removed to route coax from the roof antennas. You can catch a glimpse of the radios and the mounting bracket in the upper right corner.
First hole on the roof drilled.
NMO installed
Some time later, and both holes drilled, NMO mounts installed, and antennas installed. I put a 440 (front) and 2m (rear) 1/4 wave whips so I could get into garages. The 2m antenna will clip most garage doors, but it's just the tip.
One year later.....
Here's what she looks like. 2/70 on hood.
I switched over to Larsen antennas for the roof because 1) They're Larsen and 2) the silver looks better.
Kenwood mounted on the top of the cubby. 4 screws hold it in place. I initially used the sticky-tape provided by Kenwood, but it just didn't stand up to the Ohio summer.
Yaesu mounted in the pocket left over from the useless sunglasses holder.
Shot under the driver's seat. You can just make out the tops of the radios.
Since the Kenwood's mic attaches to the body, rather than the head, I mounted the mic to the front of the center cubby and just ran the cable down in between the driver's seat and the center cubby.
NMO installed
One year later.....
