I had a brain storm the other day and was going to come here and hint to Uniden for a firmware idea that would be awesome -- but then I found in the manual it already exists.
We know to shut down an SD based scanner you need X seconds to write, so if you leave it wired to your ignition chances are you're going to corrupt your card. Short of Uniden adding a physical ignition pin to the scanner with a capacitor that lets it stay powered long enough to write ignition based operation is probably not coming any time soon.
But I have a charge guard in my car between my battery and all of my toys because sometimes I leave them on with the car off. This got me to thinking if you could tell the 536HP to "auto shut off" in a time frame that is no longer than your maximum Charge Guard time you'd be fine. (The Charge Guard can also shut off if the voltage drops below 11.5 or so to protect the next start)
So in theory if you tell the 536HP to shut off after say 1, 2 or 3 hours you could technically "leave it on" all the time wired to constant 12VDC through a charge guard. If you left your vehicle off for an extended period of time the 536 would auto off and presumably close the SD card writes cleanly, right?
Or am I missing something obvious with this idea?
* Obviously manually shutting it off remains an option, but this offers a CYA protection.
