- Joined
- Aug 23, 2002
- Messages
- 3,620
I have the current FW 536 with the Uniden GPS receiver.
This is what I am running into:
The scanner does not automatically update the scan lists as I travel around the area. I have the range set for 1 - 5 miles as I am testing this.
Disclaminer: I do not have the GPS plugged into 12vDC - however the scanner does get a general location when I go into the autolocate.
Part of the issue I am having is that its not really ranging anywhere close when I went out of state. For instance, I was in City A, and asking if I was in County B 50 miles south. I would select no, and then ask if I was in County B, further south of County A. GPS receiver was on the dashboard with a clear view.
I haven't played with a Uniden GPS enabled scanner (I do have a HP1, but never hooked up a GPS). My understanding is that as you move thru your "Range", it should auto update. Currently, the 536 is not.
Any suggestions or what am I missing, I don't see anything obvious.
