W4UVV
As a point of reference only.... I have a 996XT with the Uniden GP18 GPS puck and it works fine. When connected I get the screen display and beep with "GPS Connected". If I have selected a System Quick Key to monitor and it is out of my current lat/lon/distance set location via software programing "Unlocked" will display and a "beep" heard and when at specified radius edge of the distant SQK, the GPS beeps with a "Locked" display on the SQK and a "beep"..
My 536 GPS issue (Lack of comparable audio/screen display GPS status feedback?)
I have viewed all three YouTube videos on 536 location scanning and as usual with most help YouTube videos my exact situation or issues never are discussed.
I programed my 536 mostly by importing my 996XT files using ARC536PRO doing editing and file transfers. My 536 works fine as a base scanner and is installed for testing temporarily mobile using a separate Uniden GP18 GPS Puck. It seems to be working as "GPS" displays on the front panel with the GP18 connected and no display when I remove it powered on.
Currently I have only local area FL systems selected to scan which they do fine mobile with the GPS interface. However, I also have many out of area radio system favorites lists programmed in my main Favorites List I wish to scan when travelling mostly in state next month. One question is when I select an out of area FL system to scan now using location based scanning does that override GPS control? I suspect it does. If I deselect that same FL to scan will the GPS select it automatically based on the lat/lon/distance settings when at that radius rim? I hope it will. Some of the terrain I will travel is relatively flat and rural but also within reception range of some distant mountaintop repeaters. It is my understanding that distances greater than the 50 mile range selected via software programming override the 50 mile maximum range setting for the 536.
I think my settings will work as programmed but I am not sure and I certainly don't want to have 536 GPS issues when traveling. I think the 536 GPS might give a quick beep when selecting/deselecting a FL but again I am not sure.
If I am specifically doing anything wrong, I would appreciate guidance to correct as to what and how to correct it. Tnx.
John
John
