To anyone looking to acquire commercial radio programming software:
What does this have to do with Gmrs radios? That's where you posted. IF your radio is transmitting on mil air frequencies then you do indeed have an issue. :roll: 73, n9zas
1. What kind of radio are you transmitting with?
2. How close is the transmitting radio to the one that's receiving it on UHF air?
3. What kind of receiver are you hearing this on?
Sounds more like a receiver overload issue than anything else, but it's hard to tell with what little info you provided.
Try separating the transmitting radio and receiving radio by more distance and see if it clears up.
Yep, like I said above, and what ecps92 said. They are too close together.
Scanning receivers have extremely broad front ends, very little filtering. Nearby transmitters, even from FRS/GMRS radios, can easily overload the scanner. It'll decode the signal and make you think your FRS/GMRS radio is transmitting on what the scanner is showing.
Move them farther apart.
Your post are too scattered with a lack of any detailed information therefore nobody can properly understand what your saying.
RE: fcc id k7gmrcee??? please explain what is K7GMRCEE? This sounds like a ham call but there are 3 extra letters in the suffix.
A. Give a brief overview explanation of the problem first,
#1. type of receiver experiencing interference, frequencies, antenna/antennas.
#2. Your transceiver causing the interference, antennas used, frequencies, power setting.
#3. Your setup, be detailed, distance between transceiver and receiver.
duel power radio ,,,, shared including none shared gmrs plus repeater mode uses both low and high powered buttons ,,, frs can use both buttons but lp only ,,,
my frs/gmrs radio is fine on recieve as long as i use a tone squelqe with it .. otherwise i hear the hotels/casinos talking plus digital garbage on bleedover
