I've got a 436HP that's running 1.3.0 firmware. I've spent many hours trying to come up with a Google keyword combination that describes this problem and find a solution to fix it.
I found this page and followed the instructions exactly as they are given.
BCD436HP < UnidenMan4 < TWiki
When I run sentinel and click on Update >> Update Firmware a window pops up that is labeled "Select microSD". In that window there is nothing to select. I went to Best Buy and picked up another microSD and tried again but I get the same thing. I get a message that says to use Sentinel to clear user data. When I try that I can't find the scanner.
Now when I go back to the original SD card I'm getting the same message that the new card gives about using Sentinel to clear user data.
I can't be the only person that's encountered this issue but I just can't find any examples or what to do when it won't find the card or scanner.
I've tried running Sentinel on two Windows 7 machines and a Mac Book Pro running Parallels.
Can someone please point me in the right direction? I'm sick of setting the clock every time I turn this thing on.
