I am setting up a Raspberry Pi feed using Darkice on a RPi3 and Raspbian Jessie Lite, a clean install on a blank micro SD card following the instructions in the Wiki on the subject. I also installed an Icecast2 server on the pi to stream locally and work out the bugs prior to going live on bcfy. All the step by step instructions went well with no errors noted.
When I try to start darkice ($ darkice -c /etc/darkice1.cfg), I get this error:
darkice: error while loading shared libraries: libjack.so.0: cannot open shared object file: No such file or directory
Googling this error message seems to indicate a missing dependency or a file stored in the wrong location.
If I try to start it using the service method in the instructions, I get no error message, simply back to the command prompt but the stream does not start.
Any ideas?
Thank you
Jim
Any ideas?
Thank you
Jim
