- Joined
- Feb 20, 2003
- Messages
- 1,162
I loaded up my 436 of the local P25 Phase II system from RR. How do I get the 436 to scan all active TGs? Do I need to put a wildcard in the system or something else?
by putting the system in scan you will pick up all tg's associated with that system, if none are locked out. if you put the system in search, you will pick up, most likely many, many tg's not directly affiliated with the system that you originaly programmed ; next county, or next city over, if their using the same type system.
No. Only with systems you have on favorites lists.Can ID search, be used with the full Database?
The next city over, on another system, whether similar or not to the one you are monitoring WILL NOT be heard, unless they have talkgroups on the one you monitor. If they do, you are already receiving them.by putting the system in scan you will pick up all tg's associated with that system, if none are locked out. if you put the system in search, you will pick up, most likely many, many tg's not directly affiliated with the system that you originaly programmed ; next county, or next city over, if their using the same type system.
The only TGs that I selected avoid in Sentinel were the Public Works, therefore, in ID Search the 436 should receive all the other TGs.
well i dont know whats going on, but my county is a p25 phase 1 and if i forget to change the selection to "id scan" ( its pre selected to "ID search" , (( freescan software)), i get many id's coming up that has nothing to do with my county at all ! thats the way it is with all my scanners; 396xt, 996xt, 396p2 maybe its something to do with a difference between phase 1 and phase 2 thing, i dont know?
