SI Group - System Type?
KD2DLL
Rotterdam, New York
Alright I do not have much experience with Trunked and Digital systems, so this is a learning experience for me.
SI Group is an industrial facility nearby me. I have found a listing of their FCC licensed freqs:
451.2875
451.3875
451.5375
452.625
456.2875
456.5375
457.625
463.7375
462.8125
464.6625
I have heard voice communications on at least 1 of the Freqs listen above and also have heard a noise on 463.8125 that sounds like a control channel. I recorded a brief clip of it: https://soundcloud.com/alex-kaczor-1/4638125a
Can anyone identify what type of system this is?
Darkstar350
Nassau County
That sound clip definitely seems like it is NXDN or "Nexedge" which is a digital voice format
used in Kenwood radios and it probobly is that "SI Group" facility near you because they are licensed
for digital voice
ULS License - Industrial/Business Pool, Conventional License - WQNT784 - SI GROUP - Frequencies Summary
The thing is that freq(463.8125) looks like its only licensed for a 4 watt mobile radio which would be
difficult to recive beyond the work site itself but i suppose if you are close enough its possible...
See what you hear on 452.625 - because that seems to be a 40 watt repeater at the site
riveter
MD
Very very quiet recording, can't personally make that out.
However, the 7K60FXE emission on that license is the emission designator typically used for DMR (MotoTRBO). May be a Connect Plus system.
KD2DLL
Rotterdam, New York
Alright, Sorry for the low volume on the recording. I am close enough that I would be able to hear a 4 watt portable with no problems as I am less than a mile from their facility. I will be able to spend some more time monitoring them in a few days.
D
DaveNF2G
Guest
451.2875
451.3875
451.5375
452.625
456.2875
456.5375
457.625
463.7375
462.8125
464.6625
You can safely ignore the 456 & 457 MHz frequencies. They are the inputs to the repeaters on 451 and 452.
The three higher frequencies without any corresponding +5 licenses would be simplex.
KD2DLL
Rotterdam, New York
Thats what I figured. I am planning to setup one of my scanners and do some logging/recording of the freqs I have and try to figure out some more based on those results.
KD2DLL
Rotterdam, New York
So the 463.8125 is an Icon IDAS channel. I have been able to decode it on DSD+ Picked up The following so far: TG 1-104 and 1-120 RID: 1-397, 1-391, 1-166
D
DaveNF2G
Guest
You have snagged a piece of the Adirondack 2-Way IDAS system. I'll give you a leg up with the rest of that site's info:
WQMM-204 Willard Mountain (Site 12)
Ch 11 462.1625
Ch 12 463.8125
Ch 13 452.8000
Ch 14 464.9250
Ch 15 451.9875
1-120 is a taxi company
I haven't seen the others you posted yet.
