- Joined
- Aug 23, 2002
- Messages
- 3,620
It appears from casual observation that the State Police section of the database is somewhat fubar.
Its listed as repeaters (the districts) but it appears they are duplex setup (the mobiles do not repeat, aka New York style where you need to listen to both freqs to hear what is going on http://www.radioreference.com/apps/db/?aid=615 ).
If this is correct, I'll change the listings so that those with DB aware scanners will hear both sides of the conversations. In ABQ now, and that seems to be the setup, unless the DB is really messed up with incorrect information.
As much as it only appears that only a handful freq's are reused around the state, I am inclined to separate out all the districts and add in correct GPS range information and note each county that the district operates in.
If anyone has an accurate list of what is used where, please PM me. When its all restructured, it should be more user friendly and read a bit nicer.
Any further information on an accurate line up and how its used would be great.
