Baofeng UV82-WP Software
Kb2Jpd
New York City, NY
Does anybody know which software I should use to program the Baofeng UV82 WP?
You mean the HP? Both work. Factory free software or CHIRP. Make sure you do the sqlech modifications so you can use it.
Great radio. Got the 82 220 version and the regular one. The extended battery and the gang charger are excellent second and third purchase.
Adam Kb2Jpd
DickH
Adam Kb2Jpd
I use CHIRP for my UV-82. Make sure you use the right cable driver, old Prolific 3.2.0.0. Other versions do not work. Also, you should not need to modify the squelch.
Your radio should have the new Voltage Check feature. Hold the SCAN button and the battery voltage will read out.
Kb2Jpd
New York City, NY
That's good advice for CHIRP for Windows machines. On Linux CHIRP works just fine without the silly Prolific driver business. The squelch mod on miklor.com is necessary and makes the sqelech adjustment very usable. Read for your information and decide for yourself.
http://www.miklor.com/COM/UV_Squelch.php
DickH
UV5R/UV82 Squelch Levels - Miklor
My squelch works just fine as is. Don't you remember the old adage, "If it ain't broke, don't fix it"? :)
zachgallop
Knoxville, TN
billy1962
82WP - the water proof model... (I do not see dual PTT on the radio either - So this looks to actually be an A-58 which is 2 years old)
Straight from the Amazon listing you posted:
Technical Details
Not actually IP tested or certified; do not submerge in water
Marvomatic
Redwood Falls, Mn
Also looking for this..
Just got mine today... And yes... there is no dual ptt witch really makes me mad and the newest chirp doesnt work... Please help..
rescuecomm
Travelers Rest, SC
Any further information on software on this model of radio? It seems to be worth the $50.00 with the sealed knobs and /\/\ type of speaker mic/programming port for outdoor use.
Bob
jonwienke
More Info Coming Soon!
VA
I have 5 of them. The Amazon vendor has a link in the listing to download the software.
jonwienke
VA
The 5-pack I ordered included a programming cable. You can order radios with or without cables, and they have a separate listing for the cable.
jonwienke
VA
No. You have to reboot the radio while holding down a key, so it's not "easy" to use the VFO, but the software doesn't offer the option to completely disable it.
