Motorola CDM Series Reference Oscillator
BlueDevil
WA
I have a Motorola CDM1550 VHF 40watt R04.01.00 mobile radio. It randomly and intermittently freezes. The screen remains on and at a glance the radio seems to be functioning until you go to transmit or change the channel or expect to receive a signal. The radio must be power cycled in order for it to start working again. Sometimes it will power right back on but most of the time the radio must sit for a fairly lengthy amount of time before it will come back on.
I have been reading about similar type problems relating to the Reference Oscillator failing. However most of them stated that their radio would not power on at all. Does this still sound like a Reference Oscillator problem to you?
Any ideas, thoughts, or suggestions? Is there a newer version of the CDM series radio that does not have this inherit problem? I would like to fix or replace (whichever is cost effective) this radio with the same make/model.
Thanks for your time and help!
BlueDevil
WA
The radio just froze up again although this time when trying to change channels it restarted on its own and began operating normally.
Do you have PL DPL code programmed in the channels? I believe radio stop even if they receive a signal from another PL DPL just never will hear sound unless correct PL DPL is received.
BlueDevil
WA
I have been over to Batwings as well. I reflashed the radio and updated the firmware and it is still having issues. From what I have been able to understand it sounds like this radio is pretty much a paper weight unless you are willing to send it into the Depot which you can replace the entire things for that price. Or you can try to live with the fact that it may go unresponsive at any time. Down side is that is doesn't just reset and fire back up. It is dead for a while before it will come back on.
BlueDevil
WA
Does anyone know if there is a model or firmware version that would indicate updated internal hardware so the radio doesn't experience these problems? I am looking at getting a replacement CDM series radio but don't want to run into this issue again. Most likely be a used radio since this radio is no longer in production.
