Hello all,
I am looking to put up a repeater and antenna on top of a building that is centrally located in town (roof of a college basketball arena) at approximately 75 feet AGL. My current repeater site (on top of our building at approximately 25 feet AGL just isn't giving me the range we are looking for. I have received permission from the school to put my repeater antenna on the roof.
The school operates a UHF repeater for their maintenance/custodial staff that is located on the top of the building as well.
My question is; How far apart do the antennas need to be spaced to not interfere with each other? The school uses 464.3250/469.3250 with a 114.8PL, my repeater would be 464.5500/469.5500 with a 114.8PL (I would have no problem with changing PL tone on my system if that would help as well?).
Both repeaters have celwave mobile duplexers and are 50w continuous with approximately 30-35 watts to the antennas. The school is using a Hustler G-Series" G6-450-3 antenna. My repeater has a Comet CA-712EFC antenna.
There is a section on the southwest corner of the roof (it is a flat roof) where there is a raised section of brick (aprox 3' above the roof itself) that the school has mounted a conduit wall mounting bracket into the brick then attached a short piece of 1-1/2" pipe to that bracket, then the antenna is mounted to the pipe. The antenna is aprox 6-8" above the 3' tall raised brick side wall. In total there is approximately 10-12 feet of usable space for me to mount my antenna, which would be to the east (or to the right of the of the school's antenna if you are facing the north). The school's antenna is mounted on the southwest corner of the wall.
Any advise, help would be greatly appreciated!
Thanks!!
Thanks!!
