Yes that too. It probably matters what I had for lunch and the relative humidity as well.
I monitored the new Denton County P25 system this afternoon in Tarrant, Denton, and Grayson counties. I found it to be exceptional -- much better than Montgomery County's P25 system. I switched to the system around the time I passed 287 on 35W. I picked up traffic and had perfect voice decodes (so I don't know the southern margin on 35, I should have switched sooner). It did fine around downtown Denton. There was a small null northeast of TWU and another in Pilot Point. Otherwise, I had perfect coverage throughout the areas of the county I traveled (I was not in your far corner of the county). My scanner decoded well into Grayson county, even northeast of Collinsville (of course with dead zones in the lower areas here and there).
I was using my WS1080 inside of the truck with this antenna: (
ExpertPower® 7.75" BNC-Male Dual Band Antenna found on Amazon). I also used an RTL with the stock telescoping antenna inside the truck. I think UniTrunker decoded the control channel till probably around highway 82 and 289, near the middle of Grayson County. Of course, this area isn't as built up as yours.
One note about "omni" directional antennas: even these can be used as directional antennas; they are only "omni" perpendicular to the antenna. Turn it horizontally, and you have a bi-directional antenna. Put a shield or reflector on one side, and you have a directional antenna.
I also looked at the topography of your area, as well as the tower placement.
I am unsure why you are having so much trouble. Perhaps very local interference, attenuation from structures, or maybe multipath. If you have a good view to your east, point your antenna to the Grapevine tower. The tower to your north should also be in reach.
However, I would like to confirm that you have your scanner programmed properly before you spend more time fussing with antennas and placement. I recommend driving around to find out if you are getting good decode on your scanner anywhere, even right below the tower.
Program only the control channel. As of earlier today, it was 859.2875. Make sure you squelch is all the way down so it is always open. Try programing a wildcard. With a high gain antenna, maybe you need to turn on your global attenuation.
Make sure your talkgroups have a delay of at least .3 seconds. That why it will stay on them instead of bouncing back and forth on every little insult.
Other things I noted:
- The Corinth radios are pretty hot, perhaps a different model than the others or they have the gain up. I'd turn on auto gain control for the Corinth PD talkgroup. I heard them fine (great, actually), it just blasts out about twice the volume of the SO, though.
- I didn't hear any Lewisville traffic. I suppose they aren't using the system yet.
- There was some traffic on a TG not in the RR database, 483
- The busiest talk groups were the three SO patrol TGs, DC Fire Dispatch, and Corinth PD.
Of course, this is just from around a couple hours of monitoring.
I think this will be a fun system to listen to once Denton and the rest switch over. It would also be fun to work with someone to setup a software defined radio solution for recording the traffic.
