KE0GXN
I noticed today whenever I key the mike on my radio, it cuts off all transmissions on my Home Patrol II. Not a major issue as it obviously prevents PS traffic from being broadcasted via background noise on the amateur bands, however I keep the scanner volume pretty low, so I doubt it will ever be an issue. With said I would still rather be able to hear my scanner when I am talking on my Kenwood.
I have tried separating the antenna feed lines as far away from each other as possible to no avail. The scanner's antenna is mounted on the same outdoor mast approximately 2 feet below the base of my 2m/70cm antenna.
Anybody know of fix for this or why its happening?
